Prikaz rezultata 1 do 10 od ukupno 30
Like Tree32Likes
tema: Tissot luxury automatic 80h power reserve
    Određen forumom Tissot luxury automatic 80h power reserve
    Tissot luxury automatic 80h power reserve-tissot_powermatic_80_640_360_s_c1_center_center.jpg
    Presented Dec 2012
    Size-Gent
    Case material-Stainless Steel
    Water resistance up to a pressure of 5 bar (50 m / 170 ft)
    Glass material-Sapph. Crystal+Non-Reflec Coat
    Dial color-Black-White-Various
    Dial type-Index
    Bracelet material-Stainless Steel -Leather
    Movement caliber-Powermatic 80
    Movement type-Automatic Mechanical
    Weight-82g (Leather)
    Diameter-41mm
    Height-9.75mm
    Tissot has been working hand n hand with ETA for the research and development of this new automatic piece. Together they thrived to push the limits in terms of precision, power and essentially giving time a new status. Tissot’s spirit of innovators by tradition and ETA’s expertise in the creation of movements is a winning combination. Both companies were able to carry each other above and beyond, leading to the production of a ground-breaking piece.
    Tissot’s recipe for success is to ally its watchmaking expertise and traditions to the benefits of innovative materials, which has proven itself time and time again. This movement was no exception to that approach and as a result, the automatic Powermatic 80 not only demonstrates ultimate precision but also has 80 hours of power reserve. Additionally, staying true to Tissot’s philosophy of offering luxury products at an affordable price, you will be awestruck by the price of such a revolutionary component.
    Works
    Standard watches would usually have a barrel that would last 36 hours before needing to be wound up again. However, with a new construction concept which integrates a new spring barrel, Tissot and ETA were able to provide the piece with a greater power reserve, allowing the watch to go for 80 hours without being worn or wound up. As if a greater power reserve was not enough, they also found a way of making the movement extremely precise and robust by concentrating on ways to improve the regulator system. One of the factors which contributed to that robustness was a new way of regulating the watch by removing the index-assembly system and replacing this item by an innovative technology.
    This new way of thinking and essential modifications have given way to this brand new revolutionary system called the Powermatic 80 automatic movement. You may witness these works in the Tissot Luxury timepieces, the first watches to feature the ground-breaking piece.
    Published in : Tissot, New arrivals
    Poslednja ispravka: Shmizla (10.1.2013. u 12:29) Razlog: Vizuelna dorada
    RUS, Don_Krstic, vladas and 8 others like this.
    Određen forumom Re: Tissot luxury automatic 80h power reserve
    Nisam previse odusevljen izgledom ali pozdravljam novi mehanizam.Kako se vama svidja?
    Ne izgleda lose.
    Tissot luxury automatic 80h power reserve-tissot_powermatic_80_montre4_640_360_s_c1_center_center.jpg
    Stariji član Avatar korisnika lemi
    NOVI SAD
    meni je super.............
    ​LEMI
    A cena jel se zna? Nisam je video mozda mi promakla Sta znam nije los sat, sto se tice mehanizama, treba malo vremena da prodje da bi imali bolji uvid kakav je
    Stariji član Avatar korisnika Don_Krstic
    Meni izgleda odlično, posebno crna varijanta sa kožnom narukvicom. A mehanizam me još više oduševljava, samo još da se dokaže u praksi. Nadam se da cena neće biti neka astronomska... Sve u svemu jedno prijatno iznenađenje od Tissota...
    VLADAN P likes this.
    Cena ...do 600$ ali nema jos u prodaji. Pristojno za ETA 2824 sa vecom oprugom...da kozni kais je bolja varijanta
    Sad nađoh da će cena kretati od 500-600 eura za regularne verzije bez COSC sertifikata...
    Sad sam video da ce ovaj sa COSC biti oko 1000 CHF~820€
    Hvala na infu o ceni Moracu da prenocim pa da bolje razmislim sta da mislim o ovom modelu , inace sve u svemu svidja mi se
